Need help changing to LS7 injectors in HP
I want to verify that the correct info is in the PCM for the injector size. I am running LS7 injectors with a 98 PCM and using HP tuners. I need help with the method used to compute this number, I have also been told that GM LS7 injectors are 39.8 and 42 @58 psi. If someone could tell me the correct flow rate for these injectors that would help to. Thanks.
