Set an SES code, what to do next to fix?
Old 05-23-2009, 05:04 PM
oddwraith's Avatar
Question Set an SES code, what to do next to fix?
I had the emissions light come on today (hate that little orange light). I read and cleared it with the predator. It was a p1416 "port air circuit"? I looked it up on here and I don't quite know what to make of the description. What is it I need to look into should this light come on again and it's the same code? Or is there action needed to be taken now regardless of the fact that I've cleared it and it has stayed off so far all day?
Thanks.
Old 05-23-2009, 05:47 PM
oddwraith's Avatar
Apparently it could have something to do with the AIR system (which is funny because I described a hissing sound I was getting once on here and someone said it was probably the AIR system).
After some more research it appears as though I may need to replace my bank 2 (passenger side) Air check valve. It may be clogged apparently. Or maybe it's the AIR fuse? Does anyone know how to change the AIR check valve? I'll post my question about this part installation over on "general maintenance" section.
