ASR OFF Light
ASR OFF Light
When I drive my 99Z28 on the freeway after about 7 to 10 miles the "ASR OFF' light comes on until I get off the freeway. Once on regular streets after a few miles the light goes off on the instrument cluster.
Any thoughts what might cause this and how to fix it?
Thanks in advance!
Bruce/StoreKeeper99Z28
Thanks in advance!
Is ASR system on a 99Z28 anyway Vacuum controlled?
I head that if you have Heads and Cam that at low RPM's it can cause the ASR light to come on?
Any thoughts greatly appreciated.
Any resolution to this?
Rx Bruce/StoreKeeper99Z28
Originally Posted by Gage
Bruce, i had the same problem,lt ended up being my front driver sensor in the hub..
Thank you for the quick reply!
How did you find out which Sensor was bad?
luckily i had a freind with a tech 2, however, check to make sure all the connections are good, should be a plug on each wheel, if those check good try cleaning the magnet part of the sensor, if that still doesnt work then one of them is bad, unfourtunatly there isnt a way to tell with out a scanner, and im not sure if the one at autozone can read that....
Thank you for the rely!
What is a tech2?
Where are the sensors located?
Thanks in advance!
Rx Bruce
Asr Light
My Asr Light Would Come On After Cam Install . I Would Also Get A P0106 Map Sensor Code . I Think The Two Are Linked Together . I Also Believe It Is Linked To Tuning , Because It Would Only Do This With A Chris Marsh Tuned Computer But Not My Ed Wright Tuned Computer . Hope This Helps .
