newb question regarding pe table
Old 05-27-2009, 07:30 PM
mike13's Avatar
Default newb question regarding pe table
The pcm uses the maf for data to keep wot within parameters set by the pe table? So if your pe table has your afr right where your shooting for if you install a better flowing set of heads your pe table should still be correct?
This is on a boosted motor that had been dyno tuned prior to the head swap.
