98 Alternator Wire Run To PCM???
Simple question... does the red wire that goes to the alternator run to the PCM on the 98's? If so, what pin does the wire go to? I did a PCM swap and now my alternator isn't working. I also installed a new wiring harness (98) and it seems everything is hooked up right.
Lastly, the red wire that hooks to the alternator... should it have 12 volts or close to that when the ignition is on? I just need to know what's going on. I had the alternator tested and it passed all tests so I know it's working. Battery will take a charge from a battery charger. I'm lost. Any help would be appreciated. Thanks.
Brad
Brad
Brad
Thanks, Russ!
I appreciate it man... damn wiring!
I think that's the plan. I imagine tracking down the break would be a royal nightmare with the thin wire and with it running through the firewall in the gromet below the PCM, behind the intake... really not looking forward to that. Thanks for your help!
