need DTC help
need DTC help
i had my car out sat. night and i noticed it started to run poorly, lack of power, poor idle etc. the check engine light came on. when i scanned it i got 4 codes.
p0103
p0108
p0135
p0155
the car has been switched over to speed density now for a couple of months so i heard the MAF code is normal. Has anyone else that has gone speed density seen similar codes? Any help would be great.
p0103
p0108
p0135
p0155
Codes
103 is Mass or volume air flow circuit high input
108 is MAP / BARO circuit high
135 is O2 sensor heater circuit malfunction (bank 1 sens 1)
155 is O2 sensor heater circuit malfunction (bank 2 sens 1)
Since your in SD, ur right about the MAF code.
I switched both my TA's to SD and no codes. In HP Tuners, I turned off SES light for the MAF codes.
Find it hard to believe that both O2's took a dump at once so check into the MAP sensor.
Have any way of checking it's output ? a scanner or a VOM ?
unfortunately i don't have any way to check it right now. i work 2 hours from where i keep the car. i had 0135 come up over the winter when the car was stored and i started it every once and a while. so maybe the other o2 just caught up? the MAP is the one that worries me more. I cleared the codes and drove the car home Sat. night and the longer i drove the worse it felt. maybe 6 miles i just didnt want to have it towed. i have a call into the tunder as well. but the same issue the car is over an hour away from then. i was looking for what i could trouble shoot on my own before arranging a trailer to get it to the shop.
remember this, with normal MAF tune, the computer relies on both the MAF and the MAP to decide fuel trims from load, when you go speed density, you eleminate one of thoes monitors, so when your MAP goes bad without a MAF to back it up, your computer doesnt know if your beating on it, or just putzing around town. all it knows is the throttle blade is open this far and i better dump some fuel in just incase im climbing a hill. so by default, it will run pig rich.
