trans od help with codes!!p0748
ok i have a 01 z28 with a rossler 4l60e with a yank ss3600 has the rossler trans brake also.....the trans is out of a 04 gto engine and trans swaped about a year ago and had no problems until this code started showing up and reverse started acting weird its delayed you put it in reverse and it takes a couple seconds to go in......the tc locks up sometimes in 3rd gear and sometimes it doesnt lock up in od it locks up when it wants and sometimes doesnt lock up at all..... i have retrieved a code and its a p0748 which is the pc switch failure anyone else have similar problem or the same code?
