MAF flow numbers? help me out please...
ok just checking on my predator i see the maf lbs/min or whatever. what does this mean? at idle im around .9-.94 or so. with the slp MAF on there it was like .7 or .8. dont know if this has anything to do with tuning the car or whatever so can someone explain to me please.
Moderator
Means that your SLP MAF is underreporting airflow by
a fair bit, the Predator only knows the standard airflow
for frequency function and the frequency per airflow
characteristic of the SLP MAF is not stock calibrated
but low (to give you more spark advance and lean out
the mixture at WOT, and either the illusion or reality of
increased power output depending on cases).
