p0507
Old 06-29-2009, 06:11 PM
00silverGTP's Avatar
Default p0507
Keeping getting this code every couple weeks. car runs fine, is idling about 900. but this time I noticed a hesitated real bad and then the light came on about 10 min later. are the hesitaiton and code related?
Eric
Old 07-01-2009, 01:20 PM
no thoughts?
Old 07-01-2009, 02:16 PM
99huggerorangeZ's Avatar
Originally Posted by 00silverGTP
no thoughts?
p0507 idle speed high. i would check for vaccum leaks,pcv system(valve),excessive deposits inside throttle body. how many miles are on your car?
Old 07-01-2009, 05:56 PM
100k.
Old 07-01-2009, 08:35 PM
100k.
have you ever changed your pcv valve or cleaned your tb/iac?
Old 07-02-2009, 07:44 AM
no on the pcv. the tb has been p/p with a new maf.
Old 07-02-2009, 11:12 AM
i would change your pcv valve it may also be from your tb since it has been opened up.
