Just a plain electrical mess
Was doing the wire location mod on the Ss to hide the 0ga and the ugly *** engine connectors that run down the passenger side of ls1 fbodies, and all went smooth except for having some roommate help .. Bottom line is there are 3 connecotrs that are involved in this relocation , a 5 wire one a 8 wire one and a 9 wire one.
which opens this three part question ?
Problem with 5 wire one is SOLVED !!!
Problem with the 8 wire connector is there are 2 Pink wires (B) and (E) positions. on 8 pin conector now I couldnt trace these back to any set pcm location as i believe they are common because i would get a continuity reading on most pcm pins but from the master pcm pin out list only 2 pink wires or red 63 (trany range signal A) and on blue (19 ign positive voltage )but I need some advise there
And now for the real pain
On the 9 pin connector there ar 6 wires in question
2 green, 2 blue , 2 pink (green J & C) (blue E & H) (pink A and G) that also seem to be every where on the Pcm so trying to corolate conector loaction (letter) back to Pcm pin # so that i can verify done right and have car start again,,,
thanks for any input
wrencher
Dont you have an auto part store that can give you pin outs?
They should be able to give you a wiring diagram or something to help.
The PCM & you connectors in question full pin out would do the trick.
Definetly a 1 person job.
ok the connectors in question ar c100 and c101(pretty sure)
my 99 book says:
c100 black 10-pin
a. pink- power feed from inj fuse 9
b. grn/wht- a/c comp rly cntl
c. dk grn- a/c comp solenoid feed
d. gry- 5v ref voltage feed
e. dk blu- tps signal
f. not used
g. pink- pwr feed from ing fuse
h. dk blu- coolant fan rly
j. dk grn- coolant fan rly
k. blk- sensor return
c101 gray 10-pin
a. yel/blk- vats starter enable rly
b. pnk- fuse output ign 1 type iii fuse
c. brn- idle speed motor retract
d. grn/wht- idle speed motor extend
e. pnk/blk- fuse output ign 1 type iii fuse
f. not used
g. orn- fuse out batt iii fuse
h. blk/wht eng cntr mod ground
j. ppl/wht- ign feed
k gry/blk- ign retard signal
my 99 book says:
c100 black 10-pin
f. not used
c101 gray 10-pin
f. not used
thanks thath helped out quite abit, but me and my multimeter have been spending way too much time together , Im very conifdert everthing is correct except the following 4 wires. I guess im gonna have to try to trace these out but if anyone knows where these terminate or have any diagram or any advise id apprecite it
c100 black 10-pin
c101 gray 10-pin
e. pnk/blk( mine is plain pink )- fuse output ign 1 type iii fuse
seems my pcm
is not getting juice because of these 4 and ive double checked all fuses adn swapped out all relays under the hood and by drivers side ..
thanks
c100 black 10-pin
c101 gray 10-pin
seems my pcm
thanks
c100-
a.- powers up inj drivers in pcm............
pins 36, 3, 76, 43
also powers up ign modules
g. evap crap power, purge and vent valve
pin a on both
also powers auto trans
c101-
b. powers up the inj drivers in the pcm........
pins 4, 44, 37, 77
plus ign modules
e. powers pcm
pin 19
there might be more thats all i can see right now
pins 36, 3, 76, 43
pin a on both
c101-
pins 4, 44, 37, 77
plus ign modules
e. powers pcm
pin 19
Originally Posted by Gen3Benz
c100-
pins 36, 3, 76, 43
pin a on both
c101-
pins 4, 44, 37, 77
plus ign modules
e. powers pcm
pin 19
pins 36, 3, 76, 43
pin a on both
c101-
pins 4, 44, 37, 77
plus ign modules
e. powers pcm
pin 19
YOU DA MAN !!! ill try it tonight
