O2 sensor code 1133,1153
Old 11-15-2003, 10:42 AM
SmithZ's Avatar
Default O2 sensor code 1133,1153
I need help solving these codes. I have replaced each O2 sensor two times with no luck. What does "Insufficient Switching" mean?!? Thanks
Old 11-15-2003, 01:18 PM
VT_01_SS_ls6's Avatar
i submitted this same question awhile back and didnt get any reponses.. i figured out what happend to me.. mine happened when a really rich condition happend while spraying with low bottle pressure... when did you experience the code??? 02 sensors getting saturated when you run way rich and they give you the p1133 code.. i was logging mine when i got this code so i kinda knew what caused mine. give me some more info on your setup and when the code occured.
Old 11-15-2003, 05:21 PM
SmithZ's Avatar
Thanks VT
I just got my car running right. Long Story. But I just replaced my spark plugs because I fouled them out. I guess I messed up my O2's also. I'll replace them again.
Quick Reply: O2 sensor code 1133,1153
