CTS-V and HPT
Old 07-21-2009, 07:30 AM
L82gofast's Avatar
Default CTS-V and HPT
Picked up a '06 CTS-V. I have HPT already. My question is if there are any special steps before tuning this car? i.e. pull the radio fuse etc..
Let the mods begin
Old 07-21-2009, 07:01 PM
Matt@SNLPerformance's Avatar
If I remember correctly, you may have to do a read entire, leave the key on, do your changes and do a write entire. I had to do this procedure on one if not the VCM would go into recovery mode.
Old 07-21-2009, 07:53 PM
L82gofast's Avatar
Thanks for the reply and the heads up on the write entire.
Old 07-21-2009, 10:18 PM
SkullV's Avatar
What Matt said is exactly right. It's really the only thing you have to do. With version 2.22 I could just write calibration though so make sure to get the latest software.
Old 07-22-2009, 07:13 AM
L82gofast's Avatar
Good deal. I have the latest SW so I should be good to go. So I don't need to pull the radio fuse right? I noticed reading the magnacharger install manual (planning ahead) that they have you pull the radio fuse before using their programmer. Just want to be sure.
Old 07-22-2009, 09:43 AM
LS1TECH Sponsor
foff667's Avatar
Usually no fuses need to be pulled but I beileve the 06 CTSV uses an E67 pcm which will require a write entire for flashing.
