Has anybody messed with injector timing? EFI Live
I have read that injector timing can really help a car run better when running larger cams. Has anybody messed with in any? I would like to try it but am not sure what way to go, increase or decrease the numbers. I have a wideband so I can monitor the fuel. I read that 20% is good to start with but not sure what direction.
Timing or flow?
If you are talking flow, then go directly to Jail do not pass go.
If you are talking timing then the stock ones are fine dont touch them.
If you have aftermarket injectors then good luck finding the proper values. A blanket 20% sounds like madness unless you have proper values.
