HELP! PCM & Wiring Question
I'm about to pull two wires out of my PCM. I've found the location (pins 26 & 66), but the colors do not match what the manual is saying.
Apparently they should be tan and purple, but they are black and gray.
Any insight? Are these the incorrect wires?
Thank you!
Thank you!
Found the answer. Forgot there was a difference in the 1998 cars.
For anyone with a 1998 vehicle with the same problem, refer to this:
http://www.ls2.com/boggs/torques/98pinpcm.htm
