No spark on a new standalone install
Hello, this may look familiar to some of you since I have been looking for help on ls1.com as well.
I am wrapping up a new standalone LS1 install in an off road race truck. The block and PCM is based on a 1999 camaro. The PCM has been flashed with a basic 99 camaro setup, with the VATS stuff removed. Since this is a new build, and I can get the dang thing to run, a crank re-learn has not been done yet.
I have tried:
Thanks
Michael Strasia
I have tried:
- New and extra ground wires to the block, coil packs and PCM and grounds test as good
- Replaced the crank sensor and inspected reloctor ring (2 plate old style)
- Test for power to coils packs at "key on" is good
- Tried swapping in a spare PCM, still no spark
- Tested for square wave signal from the crank sensor at the PCM (voltage fluctuated between 1v and 5V during cranking, so I think that is good.
Thanks
Michael Strasia
Can anyone tell me how to test for the fire signal to the coils? Im not at all sure Im testing for the right thing since there seems to be conflicting information on the web about what that trigger signal would look like. Thanks
ms
ms
