newb question: Can tuning change torque curve?
I checked the stickies with no luck so this is probably a dumb question.
Can the torque curve be adjusted with tuning or is that only possible with a cam? More specifically I'm wondering if the motor could be tuned to give up some high end horsepower and gain some low end torque.
I just bought the truck and the previous owner built the motor. Here are the current specs:
2004 6.0L block
-LS6 ported balanced oil pump
-LS2 timing chain
-Ported and polished 6.0l aluminum heads milled 12 thou for 9.8:1 compression
-3 angle valve grind on stock size valves
-Comp cam 918 bee-hive valve springs with titanium retainers
-Thunder Racing TR220 camshaft, 220 intake 220 exhaust duration, .568 lift with 112LSA
-Thunder Racing chro-moly 7.400" pushrods
-LS1 lifters and rockers
-Ported and polished TB
-Bosch 30lb/hr fuel injectors
2004 6.0L block
-LS2 timing chain
Well you can always adjust your fueling and spark curve to maximize torque to some degree. Of course you need a dyno and a good tuner.
In reality a cam and/or heads that changes the engines Volumetric Efficiency (VE) is far more influential in dictating your HP/TQ curve. But, you can always bump some spark advance in down low, and enable additional fueling (PE) at a lower rpm and throttle opening.
May not be as dramatic as you want, but you can give it a try.
Good luck.
..WeathermanShawn..
Good luck.
..WeathermanShawn..
Moderator
You can certainly "give up" any amount of horsepower
you like, but you can only "add torque" as far as the
airflow (cylinder air mass per stroke) will support. A
bit of spark, a bit leaner, OK - but after you get to
ideal-for-the-mechanicals, the only thing left is the
mechanicals.
mechanicals.
Thanks for the help. I'm getting more used to the power delivery now but it sounds like if I want a change I'm going to have to go to the old man cam and a new tune. I wonder if I would need a new torque converter if I went to that smaller cam.
