torque management and drive by wire help
GRRRRRRR, this isn't working well. i have serious TM, i went thru the steps and still have it bad, expecialy the closing throttle blade at the shift.
here is what i did.
1. Transmission -> A4 Shift Firmness -> Torque Reduction...Fill the whole table with zero's
2. Trans Calibration -> A4 Shift Firmness -> Upshift Torque Reduction...Fill the whole table with zero's
3. Engine -> Ignition -> Max Torque...Set it to 639,
4. Engine -> Ignition -> Torque Reduction...Fill the whole table with zero's
and it didn't seem to make any diference, this things falls on it's face HARD at the shift. here is a section of atap, remember i had it floored the whole time.
here is what i did.
Originally Posted by parish8
i get the negative timing every time i shift at WOT, it is very repeatable and yes i do have drive by wire(no cable)
Originally Posted by moregrip
you ever figure this out P?
what a rush!
yeah, most of the problem was in the ETC(electronic throttle control) tables. i thought that was traction control so didn't really mess with it. i have ran into some other problems along the way too but was able to program them out too.
in this table, should all values be 100?
ahhh, I see, can you help me out here?
