I'm missing MPH in the 1/4
Old 09-05-2009, 08:31 AM
MUSTANGBRKR02's Avatar
Default I'm missing MPH in the 1/4
Well i went to the track last night and was not very happy. I had a best motor pass of a 12.91@109. With my mods i should be trapping around 112-113. Any help anyone?
Mods: torquer V2 113, Mac mids, !Cats, Borla CB, Lid, Ported TB and MAF, 3400 stall in a 4l80, MT ET DR's, full rear suspension. AGX shocks all corners, battery to the trunk
Car is a 02 T/A vert probably weighs around 38-3900 with me in it.
Prior to this I ran a 12.82 with it. On that run i had a break in the TPS wire and it fell on its face at the 1000' mark. Car Didn't 60 well but my MPH should be higher then.
Bill
File Type: hpt
Old 09-05-2009, 08:44 AM
69LT1Bird's Avatar
Why are you running a MAF if you are going to leave it failed? Did you do that on purpose or did you forget to enable it after the VE table tuning?
Engine Diagnostic - Air Flow - MAF Fail - you have it set to zero, set to 13500 if you want it to work. Reset the DTC's for it also.
Go tune you MAF after that, post a log file also.
Old 09-05-2009, 02:02 PM
Ahhh yes i did forget that i will do that here in a few. Thanks.
Can't post a log file of it running till my new laptop gets here. screen is about to fall off of this one.
Old 09-06-2009, 10:48 PM
JDMC5's Avatar
that definitely sounds slower than it should. Do you have a scan of a wot run?
Old 09-07-2009, 07:41 AM
Not right now, waiting to buy A new laptop in a few weeks.
I fixed what LT1bird said and now I have to wait for it to stop raining so I can go check the maf tune.
