VATS delete
VATS delete
This is how i deleted VATS. #1, VATS was deleted from the ECU, but then the car still will not start because of the BCM. So #2, I grounded out the yellow wire (with the black line on it) that comes from the starter relay in the under hood fuse box. There is a large purple and red wire and a smaller green wire and smaller yellow wire with the black line. just ground out the yellow wire coming out of the relay to the body and the car will crank.
I believe that if you just ground out the yellow wire, but dont delete VATS from the ECU that the car will just start and die. The way you delete VATS from the ECU is to use a tuner.
