O2 sensor and open loop and tuning questions?
So I'm tired of having o2 sensor issues. My question is if I unplug the front o2's it will keep the car in open loop correct? Just looking for it to work until I can get a tune next month.
Unplug the maf and the front o2 sensors that should put it in open loop sd. It will revert to the low octane timing table and will probably not run right. Or you could just unplug the o2 sensor and leave the MAF plugged in to run open loop maf which will run on the high octane table.
