What Laptop is everyone using for EDIT?
Just checking in on this, I got a Dell Inspiron 7500, 600 MGHZ, and wanted to see if anyone else was using this laptop. I heard many people had problems with the Ports and cables matching up and had to use adapters I wanted to know if anyone was using this laptop.
Thanx
Thanx
The new HP's and Compaq's are available with serial ports. Not all models have the serial ports but most do. These are the only ones I have found that still have a standard serial port.
Does anyone have any pics of what type of port I should have?
or can someone give tell me what I should call Dell and ask about?
I'm not the uber computer guru type and I just wanna know if I have to run an adapter or not before I buy edit
http://www.cablestogo.com/product.as...=502&sku=24742
Go here. Use goggle and find out lots of good stuff.
I prefer the sony vaio. They are only 2lbs and dont get hot on your lap. I tune other cars using this one but i do have a inspiron p3-1ghz and a inspiron c-450 for other tasks like datalogging the wideband.
you guys ever built a obd-2 sniffer? they are fun
Don't buy a new machine...
for 100 bucks or less you can buy an older laptop and keep it dedicated to car stuff. I use IBM 133mhz thinkpads, they are dirt cheap and are good enough for car use.
