P0300 random cly mis-fire
Just rebuilt my bottom end and bought MTI head and cam. Had the random miss fire before the rebuild. Reason for the rebuild was had broke ring lands in NO.7 clyinder. Now since the rebuild still get the random mis-fire. Could this be caused by the cam and heads with no tune? Any help would be great. Thanks
Restricted User
Is it actually misfiring, or is the PCM just incorrectly detecting misfire due to crank position sensor being disturbed during the rebuild?
Maybe all you need is a crank position sensor relearn.
More info here:
http://www.seattleautomotive.com/ckpdoc.htm
More info here:
i did h/c on my friends 99 ss and it would set the code if it would idle for a 5 minutes or longer, the missfire counter is works off of the crank sensor and crank velocity and when you put a cam in it gives the crank velocity and the pcm thinks the engine is miss firing when it is really not. get pcm programmed and it will take car of the problem
