would a mass air code make the car slower?
Old 09-16-2009, 12:33 AM
zach_ws6's Avatar
Default would a mass air code make the car slower?
p0101-Mass or Volume Air Flow Circuit Range/Performance Problem
its the only code the car has thrown in a long while, i went to the track and the car traps 5 mph slower now.
Also, its a cammed car with tune, anyway it now has this big mis, or cut-out at 6k.
Old 09-16-2009, 01:10 AM
JonCR96Z's Avatar
If it thinks the MAF has failed it will use your VE tables for airflow, which could be off. It would also run solely off the low octane timing tables which could also hurt power depending on the tune.
Old 09-16-2009, 02:55 PM
wait4me's Avatar
Jon is correct, you will loose power as it will revert to low timing tables. Your fuel will be rich or leaner also depending on the tune.
Old 09-16-2009, 04:34 PM
zach_ws6's Avatar
thanks guys. it was no fun being at the track last night. i have got to figure this out.
Old 09-16-2009, 04:39 PM
kamarobuddy's Avatar
I Ran into the same thing myself. I went to the track and made a few pulls, all of a sudden the check engine light came on. My trouble was a bad fuse under the hood and that was causing the code to be thrown. If I remember right the was a 10 or 15 amp fuse that was blown. So hopefully it is a simple fix like that!
Old 09-16-2009, 04:44 PM
zach_ws6's Avatar
hell, that'd be too convenient.
JonCR96Z's Avatar
Yeah that's easy enough to check. Look for the 20 amp ENG SENS fuse under the hood.
Old 09-16-2009, 06:05 PM
ND2RACE's Avatar
I had mine on the dyno recently and the first pull was only 344hp. It had kicked a MAF code and diverted back to the low octane table. It was a stupid mistake on my part, but the next pull jumped to 403 hp after I fixed it.
Old 09-16-2009, 07:07 PM
zach_ws6's Avatar
i see. you said it was something stupid, but what was it in your case?
Old 09-16-2009, 07:30 PM
ND2RACE's Avatar
Forgot to totally disable the MAF.
Old 09-21-2009, 05:30 PM
zach_ws6's Avatar
so i did a couple things that may have fixed the problem. light hasnt come back on and its been 5 days, but i guess i wont really know until tomorrow night at the track :/
