Connecting FlashScan V1 to the LM-1 LM1 wideband controller
I'm wanting advice and direction as the title says.
As for wiring, do I just connect the LM-1 analog #2 (white) wire to the FlashScan V1 A1 (AD1) input? Any grounding needed?
And for the EFILive PIDs I've included these two:
Is there anything else I need?
What should I expect to see in the EFILive Scan Data - just a 0 - 5 voltage?
Can this be tied into a Dashboard gauge? If so, what gauge would that be?
Open the scanner and hit F1. In my version of the help file, the answer is on pg 108. See pic below.
As for the PIDs, there should also be a calc AFR for the default LM1 settings. If you decide to change the voltage vs AFR spread with the Innovate software, you'll need to create a custom PID to support it.
Personally, I like to use:
11:1 = 0v
16:1 = 5v
I changed the sae_generic.txt file (which is really a no-no ) so I didn't have to create a custom PID. Easiest way to find this file is to hit the start button and search all files/folders on your computer. You can do this like I did, but it will not carry over if you re-install or upgrade the software. All that means to me is, you need to make the change again. Anyway...to get the above settings to work, I found the LM1 section of the text file (Ctrl F is your friend) and changed it to say:
# Innovate LM-1 WBO2
*CLC-00-928
V_____________0.0___________5.0___________.1 "{EXT.AD1}"
AFR___________10.0___________30.0___________.1 "{EXT.AD1}+11"
*CLC-00-929
factor___________0.0___________2.0___________.1 "{CALC.AFR_LM11.AFR}/{GM.AFR}"
*CLC-00-930
V_____________0.0___________5.0___________.1 "{EXT.AD2}"
AFR___________10.0___________30.0___________.1 "{EXT.AD2}+11"
*CLC-00-931
factor___________0.0___________2.0___________.1 "{CALC.AFR_LM12.AFR}/{GM.AFR}"
It's probably wise to create a copy of the sae_generic.txt file and save it in a safe place "just incase."
11:1 = 0v
16:1 = 5v
*CLC-00-928
*CLC-00-929
*CLC-00-930
*CLC-00-931
SSpdDmn, I used the resident PIDs designed for my LM-1. It all seemed to work as the WB data seems to be correct in the log.
I couldn't find the sae_generic.txt file. I wonder if it was not included in my version or that perhaps you have acquired it post installation??
Anyway, thanks for your help here and for other things. Please watch for my post about spiking at full throttle.
You are very right and i do not understand why windows search missed it on 4 or 5 separate searches. I spelled it right and even used wild cards in case it wasn't a txt file. Oh well, thanks for pointing to it.
Do I still need to edit it? Never mind on that. I see now that SSpdDmn changed the params in order to alter the voltage spread.
Is there any chance those changes will help the huge WOT lean spikes showing in the LM-1 data log?
They appear exactly as the RPM begins to drop - closing the throttle...
Can you tell what those changes to the sae_generic.txt file actually do. I've added the changes and saved the original - thanks.
Here's a picture of the spiking. RPM in black, AFR in orchid. Please tell me what you think. No spark knock btw.
If you would like me to send you the data log, I would surely want to send it.
Last edited by 01Z28M6; 09-28-2009 at 03:38 AM. Reason: adding blah blah blah stuff
... If you decide to change the voltage vs lambda spread with the Innovate software, you'll need to create a custom PID to support it.
11:1 = 0v
16:1 = 5v
I changed the sae_generic.txt file ...
*CLC-00-928
*CLC-00-929
*CLC-00-930
*CLC-00-931
11:1 = 0v
16:1 = 5v
*CLC-00-928
*CLC-00-929
*CLC-00-930
*CLC-00-931
*CLC-00-928
V 0.0 5.0 .1 "{EXT.AD1}"
AFR 10.0 30.0 .2 "{EXT.AD1}*10"
*CLC-00-929
factor 0.0 2.0 .2 "{CALC.AFR_LM11.AFR}/{GM.AFR}"
*CLC-00-930
V 0.0 5.0 .1 "{EXT.AD2}"
AFR 10.0 30.0 .2 "{EXT.AD2}*10"
*CLC-00-931
factor 0.0 2.0 .2 "{CALC.AFR_LM12.AFR}/{GM.AFR}"
I see that you changed all the *10 to *11 and some of the .2 to all .1
I know that I'm really going to appear ignorant but what does the changes do?
*CLC-00-928
*CLC-00-929
*CLC-00-930
*CLC-00-931
*CLC-00-928
*CLC-00-929
*CLC-00-930
*CLC-00-931
As for the .2 to .1, that's just how many decimal places you want AFR to appear to have in the scanner. I'm good with just 1 instead of 2.
Incredible! Where did you learn all of this?? I am so far behind, I don't even even know where to start to pick this stuff up...
Anyway, what I did was to change the sae_generic.txt file WITHOUT re-programming the LM-1. You can guess what kind of data I ended up collecting. I'm going to save and go over these things and try to grasp the concepts. Thanks for taking the time to explain!
I guess it's obvious but is pretty much everything I need to know in the documentation? Is that primarily where you're getting all of this? If so, I'm going to print the thing out and keep a copy in my library....
Even the F1 help while in the application was new to me. sheesh!
In time, grasshopper.
