Got a lean bank 2 code - need a little guidance.
Old 12-02-2003, 06:20 PM
Glenn98ZM6's Avatar
Default Got a lean bank 2 code - need a little guidance.
i've had a lean bank 2 code pop up the last couple of times i drove my car. i pulled a plug on that side, and they are white, so it looks to be lean. the weather is about 50-60 for a high and the only change made to the car lately was a 2 core radiator which has kept the water temp around 150 to 160 degrees. i know this is low, and i'm gonna raise the fan on/off temps some, but would that cause a sudden change that would make this code start to appear, or did i just loose an O2 finally.
Old 12-03-2003, 02:16 PM
Glenn98ZM6's Avatar
any input at all?
Old 12-04-2003, 04:37 AM
TPCRacing's Avatar
Originally Posted by Glenn98ZM6
any input at all?
It's been my experience that faulty injectors are sometimes to blame. Just some food for thought.
~Ty
Old 12-04-2003, 04:46 AM
Smoke_Ford's Avatar
The O2 may have gone bad. It may sense a rich condition and send a lean command. What are the LT fuel trims and the voltages that the O2s are sending?
