no spark
Old 10-10-2009, 05:00 PM
Scully's Avatar
Default no spark
we are trying to fire the car for the first time. we have power, fuel, the bigstuff3 is working properly, but when you pull a coil wire their is no fire. what could be the issue. please reply if you have got an idea or call 5023792220 thanks
Old 10-10-2009, 05:49 PM
KrisXpc's Avatar
Make sure your coil harness is plugged in and the ign relay isnt bad.
Old 10-10-2009, 08:07 PM
Scully's Avatar
coil harness is plugged in everything is fine. could it be in the crank sensor? just trying to rule that out.
Old 10-10-2009, 08:28 PM
KrisXpc's Avatar
or a bad ground
Old 10-10-2009, 08:46 PM
msperformance's Avatar
it should be from crank sensor or the calbiration you enterd in Bigstuff tune.
