Just finished turbo build, first time using HPT, having issues. . .
I just buttoned up my car after a four month turbo build in my garage. Heres a run down of the setup
Stock shortblock with 317 heads and ls6 cam
60lb injections
TC76 with a front mount
2bar SD
This was my first turbo build and i purchased hptuners for the sole purpose of learning how to tune this setup, i have done very basic PE and system changed on bolt on and cammed cars but nothing serious at all.
i followed a couple tutorials and online guides and books and got a general run down of the tuning setup and im just going to take it very slow and learn as i go.
Fast foward to tonight. finished up the car mechanically and pulled the tune off of it to modify. Old setup was a heads and cam setup that did a little over 400 rwhp. Modified spark and VE, changed gear ratio and tire size for current setup, changed injector values, lowered the idle to 850 (was at 950 for cam), basically followed the 2bar SD setup on the help section.
Good news: AFTER FOUR MONTHS SHE FIRED RIGHT UP!!!
im ridiculously excited about this
Bad news: Something is up with what i can only imagine is the base tune.
It will idle fine, wideband at +/- 15.1 at idle, sound great, for about 10-15 seconds. after that the rpms drop and the wideband reads lean at approx 18 and it chugs really badly. if you attempt to touch the gas it bogs really bad and basically kills it.
Can someone take a look at the base tune and point me in the right direction. i have also attached the very short log of the start up
thanks
60lb injections
2bar SD
thanks
for some reason my innovate lc1 wont connect to my laptop. i have everything wired to run it through the ac pressure sensor but i cant connect it to change the parameters. i am going to try again tomorrow
ill add some fuel to the PE tomorrow after work and see what happens. i dont want to leave it running long when the wideband starts climbing though
Get it logging the right stuff and it'll come around.
The best way is to log it and see what needs to be done, then do it.
There are ways to go about it other than that, but they will just be hacks at best and will probably need to be redone anyway. So just take the time and figure out how to log that wideband and do it right the first time.
Ryan, if you can afford to put another $125.00 into it send the pcm to Frost. He will set you straight. He sent me a great initial tune for my new motor and is currently helping me fine tune idle and cruise.
