what happens at 70 seconds??
i posted a thread a couple days ago about base tune issues on my first start on my turbo build. well i completely scrapped that first base tune and started over and definitely made some improvements.
but i have a question. what happens with my tune at 1 min and 10 sec into the startup. prior to this point the car idles low, afr is lean, and timing is low, then at 1 min and 10 sec everything changes at it turns much better. afr is good, timing is good, actually ran for 6 min and 20 seconds beautifully and came up to operating temp for the first time in four months
this log was done last night but i did another start up tonight and it did the exact same thing.
im new to hpt and would love some insight on this
thanks
thanks
Moderator
Pretty weird, a little spark bump and then things just get a
whole lot better. Could you maybe put up your config file
for this log, I don't think I'm seeing everything because it
defaults to mine.
defaults to mine.
