0 vaccuum
Old 10-24-2009, 10:54 AM
tkimrey's Avatar
Default 0 vaccuum
Not sure if this is the right section but I just got my car tuned for the new turbo setup and now it won't start. Well it will start about once every 30 tries. My gauge is showing zero vaccuum at startup and it's not deviating. It was doing this when it was on the dyno as well and my tuner said it was strange, because the map sensor was showing zero as well.
Why is my motor not pulling any vaccuum to start??
Old 10-24-2009, 06:44 PM
Old Geezer's Avatar
Map sensor shows nothing, key on, engine off???
Old 10-24-2009, 06:50 PM
luigiandme's Avatar
Does it seem to run fine once you do get it started?
Old 10-24-2009, 11:08 PM
tkimrey's Avatar
Whenever it does start (rarely now) it is running great at wot, part throttle still needs some tweaking but if I can get it started I'll get that sorted out.
The times it was doing it on the dyno the map wasn't reading anything with the key on/engine off. My tuner said it was the weirdest thing he has seen and didn't have any idea why all of a sudden it was doing it.
Old 10-25-2009, 07:59 AM
Old Geezer's Avatar
"The times it was doing it on the dyno the map wasn't reading anything with the key on/engine off."
Find this problem, and correct B4 you go further.
Bad sensor, bad wiring, defective plug???
Old 10-25-2009, 10:57 AM
tkimrey's Avatar
Yeah, the map and my gauge both (which are independent of each other) were reading zero at the same time.
It's a new sensor but it may be bad and the wiring from what I can tell looks ok, I'm going to play around with it a little today and see if I can come up with anything. Cross your fingers....
