FAST A/F digital dual sensor meter?
Anyone use the FAST A/F digital dual sensor meter? I was thinking of putting one in my C5 for mainly just monitoring the A/F ratio while at the dragstrip when spraying it....
Is it worth it? and will it read in real time? for example while going down the track if one bank is running lean is it fast enough to display this so you can shut it down before hurting engine?
And if i understand this correctly, you can playback the run?
Thanks
Thanks
