need best scanner which one?
hello
my freind wan to buy just scan hardware no tune .
work with laptop
what we need is:
1- give as what cylinder have misfire
2- which injecter not work
3- which o2 sensor have issuse
like autotap but when talk to some sponser here he say no one use autotap and can't get me one
so it's available or the company not sell it any more
what what scanner you think it better then autotap and give us what we want
plus good price not to high
work with laptop
what we need is:
LS1TECH Sponsor
Check out our VCM Scanner only at www.hptuners.com which now has generic obd2 scanning in addition to the enhanced scanning of all the vehicles that we support with the editor.
May not sound like much but if your wifes hyundai throws a code its always nice to just be able to hook up and scan it
hello
work with laptop
what we need is:
work with laptop
what we need is:
I don't recommend it as a tuning scanner, but I have used it on the following makes of vehicles: Toyota, Saturn, Ford, Pontiac, Honda, and should work on all OBDII-compliant vehicles. I have used it to debug overall injector issues, O2 sensors, etc. using the generic OBDII parameters. I also have the enhanced parameters for Ford and GM vehicles, which have many more vehicle-specific parameters.
IDK if your vehicle outputs individual cylinder misfire or injector data. If it does not, no scanner will be able to read the data. IMHO, that is the set of questions you should be asking.
If you plan on eventually tuning invest in either EFI live or HPtuners you can upgrade. I have efi live its a awesome scan tool i also have autotap its ok for general auto repairs though i hazve used it for tuning when i didnt have anything else. The other option ive used and its pretty cheap laptop based and does body and air bag is pcmscan i use it when i tune using tunercat obd2 stuff non-sponsor information removed
Anyhow...
I have autotap and its pretty useful. Many parameters aren't available though for most cars. So if you want to see individual cylinder misfires on your car in real time, won't happen. However, if you get the GM/Ford/Chrysler enhanced parameters, you can pretty much see everything that you could with a manufacturer specific scan tool, including misfires on each cylinder, knock retard, ect.
The EFI LIVE scanner is the best software scanner bar none for these engines. Plus for the most part if your just logging day to day you can view the data on the LCD screen of the V2. HPTuners sure as hell can't do that.
