Oil Pressure to PMC
Oil Pressure to PMC
06 GTO PMC and LS2 in stand alone application. OEM dash is not used.
In looking at an adaptor for the oil pressure sending unit this vendor states
"When installing aftermarket gauges, the OEM oil pressure sender is not required by the PCM and may be replaced by the aftermarket sender of your choice."
Is this true?
Is this true?
