EFI Live 98 2bar sd base tune?
My car is now tuned with HP tuners with a MAF. I am now running alot more boost and have bought EFI Live and would like to tune it for 2bar SD. I have searched the respository for a bin file for something close but did not see anything for a 98.
Does anyone have a file saved that is close to my set up that I can use for a base tune?
414ci
60lb injectors
m6 (changing to th400)
355 gears
gm 2bar map 12615136
14 psi
414ci
60lb injectors
355 gears
14 psi
I'm on Efi Lives web site right now and it state ( supports 98 camaro, 97-98 corvette, 98 firebird) with V1 and V2. Gen III LS1 97/98 PCM - Stream S-LS1-A.
I was thinking about swapping pcms to a 99+ because I was making more than 2bar but I decided to turn it down and tune sd on what I have and build another car for more boost.
Anyone else have anything?
EFILive supports '97-'98 PCMs but does not offer a COS for them.
Stream S-LS1-A means that you can tune unlimited '97-'98 PCMs.
The list of OS to COS is on page#4 of the Custom OS Upgrade Tutorial.
