tunnercats help
tunnercats help
i have a 95 z28 an the tunnercats software, i am having trouble getting the software to read the pcm. it starts to read gets about half way and stops says it "had a cable failure" i have read the installation instructions over an over, pretty sure everything is setup properly. anyone have any suggestions or tips? thanks
the cable is brand new bought it from tunnercats i have not got it to work yet, i have pcm communicator an cant get it to work also. with tunnercats i can get it to read the vin so i do know its somewhat reading. also i dont think this would matter but i do have a pcm out of 94 that has a tune on it already in the car.
9-Second Club
Could be a dirty/poor connection. If you have a usb cable, try another port in your laptop, or another usb cable. I have both usb & 9 pin serial cables, and have had cable and connection failures with both kinds. Likely you have a problem with a cable or connection problem between your pc and the module in the cable.
i have a usb cable, an 6 comm ports on my lab top. i have tried all 6, ill mess with it some more an see if i can come up with something. thanks for all input
What is the voltage on the car when it is happening? A small car charger might help.
Also, maybe changing the port settings in your control panel to allow faster transfers might do it? I think most of the time, the ports are set to 8600 or something really slow. move it up to 112k or 56k..
