No injector pulse..Help
Old 01-13-2010, 03:36 PM
CTS-Vette Eater's Avatar
Default No injector pulse..Help
Just went to start a new build for the first time. The setup is a stock 05 ECU with a AEM driver box, Delphi low imp. 96lb. injectors. I am not getting any pulse at the injector. I do have 12V at the injectors and the box has a good ground. Any ideas as to why I am not getting any pulse?
Old 01-18-2010, 04:49 PM
NoGo's Avatar
Driver boxes can be a pain in the *****.
If it is not too much of a pain I would swap in your stock injectors driven directly off of the PCM and see if the car at least starts.
If it does, then you know your issue is with the driver box, or between the PCM and the driver box.
If not, then you know your problem is VATS etc...
