02 Camaro SS rough idle and thick smoke
I started my SS today and went to bring something into my house while it warms up and I come out to check the tire pressure. Then while I'm doing that I notice it sounds different and a little bit of smoke coming from the exhaust. I pop the hood and the motor is shaking more than normal for idle and all of the sudden the smoke gets really thick. I drove it to the end of my street and it smoothed out and quit smoking but i was afraid to drive it before i found out what the problem was. Its never ran bad ever and I had to go to my first day of welding school so I didnt want to risk it and just took the Buick. Anybody have any ideas what would cause this? Would it be safe to drive it 9 miles to the auto parts store to have the codes checked? Any help is appreciated.
Had a similar experience once. Turned out to be just some bad gas, or a momentary 'clog' of an injector (dirty).
Bottom line, if it does not repeat itself..and it corrected itself quickly..might have just been some fuel contamination.
Maybe just try a fresh tank of gas and some fuel cleaning additive first. If it is a bigger problem, it will repeat.
Good luck.
..WeathermanShawn..
Good luck.
..WeathermanShawn..
