ed wright mail order tuning
Old 12-22-2003, 05:07 PM
yun
yun's Avatar
Default ed wright mail order tuning
i am fixing to be installing my agostino cam 550\550 240\240 112 lsa cam pacesetter headers and a few other things should i let him do it or anyone know a better or cheaper place.
thanks justin
Old 12-22-2003, 05:27 PM
JMBLOWNWS6's Avatar
Get someone else to do it if you can local. It would be allot better. Less down time and you can get updates quicker.
Old 12-22-2003, 08:53 PM
2000silverbullet's Avatar
Ed did a great job for me.
Old 12-22-2003, 08:57 PM
Restricted User
2001 Pewter WS6's Avatar
Are you putting that cam into a 346??? Good Luck, I don't think GOD could get the tune on that right with out starting, stalling and drivability issues. Good luck and let us know how it turns out. Ed is pretty good but you definately need a good local shop for that one...
Old 12-22-2003, 09:12 PM
Team ZR-1's Avatar
That type of cam grind does cause engine vaccum to change and will require a good custom tune of PCM to align that cam to start, idle and low engine RPMs to function correctly.
FYI, wright tends to lock the PCM, once that happens you are stuck using him from then on for future tunes or have to pay to have PCM forced reflashed back to stock to be able to use another tuner.
thanks justin
