Wideband power
Wideband power
I would search for this but I'm typing from my iPhone and it's a bitch to use sometimes but, Ive seen people hook their wideband up through their egr to get signal through to hptuners, I'm just wondering what wire they're using and if this wire is good enough to be used as the power wire to power the wideband? If it helps I'm hookin up an ngk afx
thanks
thanks
Alright i found a thread that says to hook into pin55(brown wire) and this use to be the EGR position signal. Is this correct? So isn't this the middle wire on the harness that plugged into the EGR valve? Can someone please give me some input?
Alright I found the answer to my own question. I can use the middle brown wire on the EGR pig tail, and ground to the battery. I've found the info to get a pid together in HPTuners. Just would like to see some pictures of where people are mounting the analog box?
Would also like to know this. I did see one guy said there is plenty of room in the center console by the shifter. Hey, if there isn't just move it somewhere else, but it's worth a shot no?
I ordered one last week and it should be here on Tuesday. I pretty much decided that I wasn't going even perminantly mount it where I could see it since it displays a value that's incorrect... or at least that's what I've gathered.
Here's what I'm talking about:
http://www.hptuners.com/forum/showth...&highlight=NGK
You can tune with it just fine as long as you make the necessary adjustments, but as for the readout I don't even want to see it... unless I just know that when it reads 14.57 it really means 14.68.
