AFR at WOT in the 3k area??
Old 03-03-2010, 06:22 PM
13 Second Truck Club
LS1FREEK's Avatar
Default AFR at WOT in the 3k area??
At what AFR do you guys usually notice the best power around the 2k to 4k rpm with a cam? Its a big deal to me cuz i dont have a stall. My mods are in my sig. Thanks!
Old 03-03-2010, 06:38 PM
LS1-450's Avatar
It depends on where you set MAP & throttle change percentage to differentiate WOT fueling from normal driving fueling. Regardless, best power would be in the 12.8-13.0 AFR range. If you tip in @ 2K it'll start @ stoich & then drop to 12.8 or so as the RPM's increase.
