Passing OBD II with EGR, AIR, and rear O2 sensor tuned out
Old 03-04-2010, 01:20 PM
CAMJAG's Avatar
Default Passing OBD II with EGR, AIR, and rear O2 sensor tuned out
After the 3 are tuned out (no SES light) and I bring my car to my emissions center will these sensors read ready so I can pass the emissions test?
Old 03-05-2010, 07:22 AM
CAMJAG's Avatar
Anyone?
I know a ton of people here delete that stuff and are daily driving. Does your emissions stuff read ready?
Old 03-05-2010, 09:55 AM
VIPRETR2's Avatar
As long as the codes are set to SES Enabled and No Error Reported you should be fine. That's how mine are set and it passes. Here are a few links I dug up on the subject.
https://ls1tech.com/forums/pcm-diagn...readiness.html
https://ls1tech.com/forums/pcm-diagn...test-help.html
Good luck,
Larry
Old 03-05-2010, 01:00 PM
CAMJAG's Avatar
Good luck,
Larry
Your the man
Thank you sir
