Tuning out error codes: no message vs disable
Title basically states it.
I'm sure all the major tuning software are the same in terms of tuning out error codes. But to be specific, I'm using Jet DST software.
Let us use rear o2 sensors as an example. I'm not running them and I want to tune them out of the diagnostic related stuff.
Jet DST gives two methods:
1) You can enable and disable an error code.
2) If it is enabled, you can tune it to no error reporting.
So, what is the "best" method for tuning out error codes? Disable it? Or no error reporting?
