What could cause only 88% TPS when Floored on 06 GTO??
I did a data long on my GTO today and noticed that I only was getting 88% TPS at WOT!!!! What could be causing this??? I will check the obvious for obstruction under the Pedel, but there is nothing there.
Since this is an electronic TB, is there something else that could cause it? Is there something in the tune or PCM?
Thanks!!
Thanks!!
what you are logging is the Throttle angle voltage... so WOT has to be above 4.0Volts and you are getting over that and will find that the 88% you are seeing is 88% of the 5 volts reference voltage
