Stock Program and 231/237 Cam??
Im installing PP st2 5.3s and a TSp 231/237 598 595 112lsa cam and i need the car to stay alive long enough to break in the cam and heads and get it over to the shop to tune it will a stock progrma work? Will it even start up?
Thanks
Wade
Thanks
Wade
doesn't lane do nice work?! he did mine too.
you will most likely have to work at keeping it idling, and starting without holding down the throttle probably won't happen, but off idle will be fine. not a problem for an M6. that's a hella cam, i don't have that much in mine. how far do you have to go? it will throw all kinds of misfire codes too. btw, you really don't need to "break in" a roller cam, that's old school non-roller applications. i'd like to hear it when it's done. should sound yummy, especially with that exhaust.
The car will run - some run better than others. You will likely have to give it gas when you are coming to a stop sign/light, or anytime you push the clutch in as it will try and die on you. However it will be fine - just semi hard to drive. Hell my car is running on the stock tune right now with some TEA big valve S2 5.3 heads and a 235/239 big lift cam.
Terminator: I love my duals, i like scaring the crap outta people as i rev it up next to them, only thing is i cant get any ricers to race me anymore, thanks for the info on the cam.
