how long do WB o2 sensors last?
Old 05-01-2010, 05:05 PM
ls1curt's Avatar
Default how long do WB o2 sensors last?
hey guys, im about to be getting a wideband for the Z. im looking at an aem uego with 800 miles on it. how long do the o2 sensors usually last? will i be fine with this one or should i just buy new?
thanks
Old 05-01-2010, 10:13 PM
WeathermanShawn's Avatar
I think I went over 20K on my last wideband O2 sensor. I have the type you can 're-calibrate'.
You could probably ruin one quicker. You don't want to run one unheated, or one that is improperly placed in the exhaust system.
As long as you can verify the accuracy of the one you are buying, I guess that is O.K. I always like new, so for $90 or less I like the peace of mind that tuning and my resultant AFR on spot on. Its one of the most important tools of tuning, so I make sure to get it right..
Hope that helps..
Old 05-03-2010, 02:57 PM
NoGo's Avatar
If you run leaded race gas with the thing, not long at all.
If you keep to unleaded gas they will last you a long time. Mine has been going for about 15k and severl years so far.
Old 05-03-2010, 04:35 PM
Moderator
jimmyblue's Avatar
I had one that was working fine, but a few trips with
the power off fixed that.
If the thing is always-on (w/ ignition) then you ought
to get pretty decent life.
