PCM relocation Problems
Ok here is the problem, I relocated the PCM inside and soldered all the wires. At the same time had to put in a new steering column and the brain for that due to the chip in the key. After all of this I tried turning it on and no go. It is turning over just not firing. My gauges are flipping out, flashing the security light along with the bright indicator and everything else will flash wildly. I am at a loss, whether I screwed up the wires or if the new computer for the key has anything to do with it. Any help would be much appreciated.
Thanks
Jeremy
Thanks
Jeremy
