new motor, tuning questions?
i just put in a 418ci 11:1 comression, a4, vindicator cam
how do i figure out what size injectors i should run? i picked up a set of 36lb ones. will they be enough?
also i cant get another intake yet.. can i still get my car dyno tuned with the stock one then put a better one on later? or will i have to get it retuned?
1 Post
36# injectors should cover that combo - If you didn't already have them, I'd say go 42's... Do you have a good fuel pump? You should put the intake on before tuning, or it will need retuned.
i have a racetronix pump and hot wire kit..just picked up and installed a ls6 intake, p&p TB with the 36lbs injectors
you think id pick up much if i opened up the intake to a 90 inlet and got a 90 TB? id like to see how far an ls6 intake can go
