quick HPTuners question
Where can I go to richen up the car in idle and cruising without really adding gas.
if I go to like 25 percent pedal or more the Trims are great. Idle - LEAN coasting with less than 25 percent pedal - LEAN
is there a part of the MAF table that I can change for those cells? Other than that the car runs GREAT no bucking no surgin with a big cam 408 stroker. No continuous or consistant knock.
I really just need to know what to adjust to fix these fuel trims.
Thanks!!
Thanks!!
