Logging 2 bar MAP in HPtuner only hits 105kpa
Ok... been trying to relearn this stuff.. what a pain. I have everything working, HPtuners is reading the wideband.... Now the MAP will not read over 105 for some reason. at 5psi boost it tops out at 105kpa, and 10psi tops out at 105kpa also.
It is a 2 bar sensor and worked before. New laptop now.
Why wont it read over 105kpa?
Thanks.
Thanks.
In the scanner goto the TABLE view. Close any open logs. Delete the MAP sensor. Right-click and choose insert. Engine>airflow>2 bar MAP (or pretty close to that path). In the chart-graph, go into the chart's setup and replace the MAP sensor with the 2bar to have it show > 105 kPa there.
its a 99 Transam - HP Tuners. Last time I used it was 3 years ago. It worked then and I had no issues. Now It doesnt. It does have the 2 bar operating system. In the editer I have the correct 2 bar MAP table but the scanner doesnt have that PID..... In the same lap top I used 3 years ago, and in another one I got also. Makes no sense.
I am not home now, but I will look at "histogram setup" tonight and see.
Will this make the "table" read right?
Someone on another board also said it should be in the table.
