3 Bar SD Tune... leaning out when hot. Help.
I recently did my own front mount turbo setup, coming from an STS setup. I'm wondering if the added heat under the hood now could be causing this or if it's somewhere in my tune.
Anyways, the car is tuned 3 bar SD open loop. No front O2s, OL all the time. After the car sits idling for about 10 minutes, the AFR goes from about 14.6 to about 19.0 and then progressively gets leaner until I shut her off. It climbs to 15:1 slowly then climbs faster after that. I've monitored the fuel pressure and it doesn't drift at all.
I wondered if my injectors were getting too hot and going funky due to underhood temps now being hotter with the turbo under the hood. I checked the injectors cold and they all ohm out at about 12.5ohm. Hot when the car does this lean out thing they ohm out about 1ohm higher, 13.5ohm. They're all very close to each other though.
I can post a log but I did it with my cable with no wideband O2 input so I'm not sure how useful it'd be. I'd have to get my buddys cable to get the wideband input.
Now that it's getting warmer out as well, if I sit at a light for a few minutes, the car will go into this "mode" (for lack of a better word). Any TPS above like 10% brings the AFR to where it should, but light throttle and idle start to go very lean (17-19:1). Then I shut it down, wait for it to cool down, and get moving down the road, then it's fine again. Going down the expressway even light throttle, this never happens.
Also going to include a FULL rundown of the car just for reference:
2004 GTO
Forged 370, 9:1
317 heads
Patriot Dual springs
LS6 cam
ARP studs
MLS gaskets
TC76 front mounted, 3" downpipe, .96 AR exhaust
46mm wastegate, 1.875" dump
FuelLab regulator 1:1
58psi base pressure
Mototron 60s
Twin Walbros
4L80e, Yank 3600
HPTuners, 3 Bar os
3 bar map sensor
Just a couple other random thoughts:
Car is in OL all the time because there's no front O2s so it automatically goes to OL. STFTs and LTFTs are inactive on the log.
Since my 4L80e swap last summer, the PCM has not known the vehicle MPH. Don't know if this could be related somehow. Did not have this problem last year with the CL/OL Maf tune though.
Also didn't have this problem with the new turbo setup 3 weeks ago with the MAF OL tune. Don't ask why/how but I did drive the car for a bit on the MAF with no front O2s. Part throttle at that time was close enough and WOT was fine because it's OL anyways.
Any ideas?
Here's a copy of the tune if you care to look. It's using HPTuners Beta though so you'll need beta to see it.
Current SD Tune
Thanks,
Adam
2004 GTO
Forged 370, 9:1
317 heads
LS6 cam
ARP studs
MLS gaskets
58psi base pressure
Mototron 60s
Twin Walbros
4L80e, Yank 3600
HPTuners, 3 Bar os
3 bar map sensor
Any ideas?
Current SD Tune
Thanks,
Adam
1 Post
Don't know what HP Tuners 3 Bar has, but EFILive SD COS has tables for adding fuel based on IAT and ECT - if ECT isn't going up, you could possibly use IAT to add a little fuel in that area. Or, just command it a bit richer in the idle cells to cover you...
