Can Diablo Predator fix my idle issue?
Hey guys, came up with a problem when I finished my valve spring change. I have a stock cam and stock motor just 1.8 rockers YT. I have a mail order Frost tune. Plus I have full bolt on's. Now the problem I changed to NGK 8 plugs for the spray and now the car will die when you pull up to a stop sign about 50% of the time. Other then that is runs great. Could the plugs do this, they are real cold? I know Frost can help but it seem like a issue I can fix with my Predator. I have search and found info on cracker idle, is this the only option? Thanks
